EXECUTIVE SUMMARY
Context
Electrical Contractors and BIM
How BIM is used throughout the building proceess
Key Takeaways
Conceptual design
focuses on spatial layout visualization and design options, ensuring everything fits together at a high level.
Detailed design
dives into the specific system that will be put in place. This phase incudes estimation of time and resources and determining quantities of materials needed, and allows for project simulation.
Coordination
makes sure there are no conflicts between the different trades interacting in the building or with the materials. This phase includes deviations and constructability.
Construction
is where logistics and processes are identified, and where pre-fabricated (pre-fab) items are included to simplify the project.
Operation
moves the project in the owner's hands. This phase includes facility management, repair, and maintenance.
Modification
focuses on changes that need to be made to the building at a later date, including retrofitting, recycling, and replacement.
Conceptual design
Detailed design
Coordination
Construction
Operation
Modification
Conceptual layouts are enhanced during the detailed design phase. Information such as manufacturer and part are added to the layout. During this phase, every element in the project is scheduled, and accurate counts are given across the project for each element type. Schedules can be:
Checks can also be run on the schedule to identify problems, such as when an item does not meet the manufacturer specifications, meaning it can’t be produced. Identifying these problems up front saves both time and money, as changes are easier and less costly to make in the design phase.
BIM identifies design conflicts in real time within the software, enabling users to identify and resolve conflicts before they impact project schedules and budgets. For example, in Figure 3 below a ductwork layout is copied from one floor of a building to the next, but one of the floors has a different height. BIM identifies that conflict so the ductwork can be adjusted for that floor in the design phase.
BIM catches conflicts, enabling low-impact resolution during design
