Overvoltage Protection: Key Changes in the 2023 NEC Around Surge Protective Devices (SPDs)
Electrical surges cost the economy $5 to $6 billion annually
This is a 40% increase over 2007
A typical building experiences up to 150 surges per month
Brian House, Mike Holt Enterprises
Article 215.18 requires that SPDs are installed for new or replaced distribution equipment where a feeder supplies dwelling units, dormitory units, guest rooms and suites, and patient sleeping areas of nursing home/limited care facilities. The SPD must be installed in or adjacent to the distribution equipment which contains the branch-circuit overcurrent protective device(s) and must have a nominal discharge current rating of not less than 10kA.
The SPD is required to be either Type 1 or Type 2. Type 1 is designed to be used ahead of the primary overcurrent protective device and has built-in safety features so that protection specifically for the device is not required. Type 2 is designed to be used after the primary overcurrent protective device.
ABB advises the best practice of keeping the length of conductors to the SPD as short as possible. Longer conductors significantly reduce the effectiveness of the SPD.
Article 242 provides the general installation and connection requirements for overvoltage protection and overvoltage protective devices.
242.9 requires that an SPD provide indication that the equipment is functioning correctly
Article 242.139(B) requires that where Type 1 SPDs are installed at the service, they must be connected to the service neutral conductor, the grounding electrode conductor, the grounding electrode for the service, or the equipment grounding terminal in the service equipment.
Kimberly Fairley, ABB
This webinar will discuss a few changes made in the 2023 National Electrical Code (NEC) that recognize this critical component in today's electrical systems.
Brian House explained the importance of SPDs and outlined key SPD-related changes to the NEC. Kimberly Fairley discussed ABB’s SPD portfolio.
Surge Protective Devices Catalog
